QN32LS03BBF (32' Frame TV screws lost)
(Topic created on: 20-11-2022 09:23 PM)
G71
Purchased the Model above and accidentally lost the screws that attachs to the back of the tv which hangs on the squared bracket holes to hang the tv. any one know the type of screw it is so I can order or go find it? I tried the Samsung parts website and it was a bit confusing to the point I couldn't find the type of screw that matched. Again this is the screws that attach to the tv not the mounting bracket screws. Thanks!
3 REPLIES 3
SereneH
Hi @G71! In which region did you purchase your TV?
G71
Los Angeles, CA USA
SereneH
@G71 Ah, okay. These are the UK/EU boards. You might have more luck on the US boards: Samsung Community - Samsung Community, or with our customer support colleagues: Support Home | Official Samsung Support US 😊
