12-01-2020 05:49 PM in
TVHi,
I planning to put a picture frame around my Q90R 55" to recreate "the frame" (but with better picture quality). However, the Samsung badge on the bottom frame/bezel is making it a bit more complex than what it needs to be. Do anyone know if it is possible to remove the Samsung badge on the bottom of the TV? It looks like it is possible to remove two screws at the bottom of the frame but I am not sure if this will loosen anything inside the TV. Have anyone tried or have input?
Solved! Go to Solution.
13-01-2020 02:19 PM in
TV13-01-2020 02:19 PM in
TV13-01-2020 06:52 PM in
TV19-12-2021 05:31 PM in
TVI have the same issue as Wooze and I’m willing to sacrifice the warranty if the badge can come off without affecting the tv controls so can it be removed?
