Go to solution Solved
TV Samsung 2019 55Q85R update problem
(Topic created on: 05-09-2023 08:30 PM)
rikob1
I have the following problem
New firmware 1406.4 is out How to upgrade as I installed 1409 half a year ago !!!???
I used this link from the moderator and installed the intermediate version 1409. But now when the new version 1406.4 is out it turns out to be lower in number and can't be installed!? Samsung what to do, how to update to 1406.4 and fix the sound problems?
OPTIONS
Hi all,
Sharing the official response on this one we received:
"We are aware of this unfortunate side effect of the software update T-MSLDEUC_1401.0 & T-MSMDEUC_1401.0, during HDMI switching Audio is forced back to TV Speakers.
We will rectify this problem when we make the next full update to the TV Firmware during 2023, but until then we can offer an interim firmware update available to download & update by USB using the following links
https://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&OriginYN=N&Model...
The firmware needs to be “Unzipped” before writing the root of a USB.
If you are unsure which Firmware you require, simply download, extract & write both to the root of a USB stick & the TV will update using the correct file.
Instructions on how to create the USB Update file can be found here:
Note: The supplied links mention 'PS42B450B1W', this is not a mistake & the correct update file is available at that location."
OPTIONS
Hi @richardhxEU ,
The links above are for all affected UK and European TV sets. For folks who are from elsewhere it's best for them to get in touch with their local Samsung Support.
AntS
Hi guys,
Update on this one from my colleagues at Samsung UK TV/AV:
"We are aware that the recently released software update (T-MSLDEUC-1406.3 & T-MSMDEUC-1406.4) are not available for those customers who previously installed T-MSLDEUC-1409.0 & T-MSMDEUC-1409.0. A manual release has been made available to enable update to the latest version. We apologise for the inconvenience.
Link for models with MSMDEUC software:
Link for models with MSLDEUC software:
https://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&OriginYN=N&Model..."
I've been advised that these should work for all relevant European models.
Downloading, extracting, writing and updating is the same procedure as the 1409 software, but just in case anyone needs the instructions again in this post:
Instructions on how to create the USB Update file can be found here: https://downloadcenter.samsung.com/content/FM/202006/20200616141207650/2019_TV_Firmware_Upgrade_Inst...
20 REPLIES 20
Pugs1957
SuperStar
You just need to unzip the update file and copy it to an empty USB drive. Insert in TV. Can't remember if you have to reboot. One the TV finds the file, follow the onscreen instructions.
rikob1
My TV is currently on version 1409 and when I insert a USB with version 1406.4 it sees the file but doesn't install it because it counts it as a downgrade
Pugs1957
SuperStar
Hmm The thread you linked to is almost a year old so may have been current at that time but is now a downgrade.
rikob1
This is the problem that Samsung released an interim update 1409 almost a year ago to fix a sound problem, and now they release an update 1406.4 which of course is impossible to install !!!
Pugs1957
SuperStar
I now fully understand.
My recommendation would be to contact customer support as I don't know how to get around this, sorry.
andr3a2
Same problem for me!!
rikob1
  1. The only option is to release the same update but with a new number, for example 1409.1, so that we can install it.
rikob1
  1. This is the last Samsung TV for me. Inadequate maintenance
AntS
Hi @rikob1 and @andr3a2  (and anyone else similarly affected),
Official statement on this for you from our TV/AV team:
A manual release will be made available in the coming weeks to allow these TV’s to be updated.
Once the update is made available we will post further information here.
We apologise for the inconvenience & assure all affected customers they will benefit from the stability updates included in the update in due course."
