21-10-2024 06:12 AM
i Was using my tv last night, and I was on my computer, left it to take a quick shower, when I turned the tv on it started making what I can only describe as sounding like when someone breathes heavily down a microphone? It was really loud and I turned the tv off immediately. It scared me so I haven’t turned it on since and I’m scared to in case it does more damage to it. I’ve looked everywhere to try and find an answer but I honestly haven’t got a clue. The tv’s like 5 months old as well since I had to get my old one replaced-
21-10-2024 06:45 AM
21-10-2024 09:17 AM
21-10-2024 11:52 AM
21-10-2024 03:10 PM
Spooky 😁. A buzzing ,crackling or humming noise can be caused by electrical feedback though this seems a bit different. Not necessarily the case but some noises can be caused by inadequate ventilation. I would disconnect external Devices, unplug from power (if have not already done so) and connect again after short period.
otherwise if you go to Settings-Support-Device care-Self Diagnosis -try the Sound Test to see if any errors identified there. possibly the Tv may need an inspection though.
