22-05-2022 01:38 PM in
TVMy TV (4 years old) has started flickering constantly, regardless of input (even with no input this still happens). Is there anything I can do to fix this? I've looked online but there's nothing helpful available.
22-05-2022 04:30 PM in
TVHi @Wowens1 check you have the latest firmware on the Samsung support site,if not can be downloaded to USB. Try the following settings, Home -Settings > General- Power and Energy Saving, advisable to disable Brightness Optimisation, Brightness Reduction and Motion Lighting. applicable. If all fine or still issue there Can you check all cables and connections to ensure everything is secure. If so press and hold in Power Button for 5 seconds or so to reboot until you see the Samsung logo. If does not solve the issue unplug at mains for around 5 minutes, you could also try a Factory Reset. If still flicker after troubleshooting do a Picture Test, Settings-support_ Self Diagnosis- Picture Test.
If tests fail you will need to get in touch with Samsung Support for Advice
One Ui 5.0,Android 13 .
26-05-2022 08:56 PM in
TVThe same thing happened to my 7470 about two weeks ago. Nothing I tried resolved the issue, so I bought a very reasonably priced OLED. The remote isn't as good but the display and app support are much better.
