05-04-2022 01:34 PM in
TVModel: EU65AU7100KXXU
I have just moved into a new house and bought the above model TV.
I have a coaxial cable plugged straight into the TV port in the wall but when scanning it is not picking up on any channels.
Any suggestions?
05-04-2022 01:53 PM in
TVThat sounds as though it could be a problem with the external aerial, @TomCooper. Do you have another TV you can try with the same aerial connection?
05-04-2022 01:55 PM in
TVHi Chris,
no I don’t. It’s a new build house so would I need to speak to the developer re the aerial set up?
cheers
05-04-2022 02:06 PM in
TVIf the aerial is capable of receiving signals, there should be no reason why the TV won't tune in the signals to your TV, so this would be a good starting point, @TomCooper.
05-04-2022 03:12 PM - last edited 05-04-2022 03:25 PM ) in
TVHi @TomCooper Best to check the aerial set up to rule out any issue there.
However if that is fine check if there are any problems with Freeview in your area https://www.bbc.co.uk/reception/problems-freeview-reception/#/Freeview other options are to try the Automatic scan again. Some customers have found that scanning after removing the aerial and then reinserting provides a solution when channels are missing and your manual tune may be accessible. In other words scan with the aerial removed when obviously no channels will be found, however this can reset the connection. You would then need to scan with the aerial connected again and see if this makes a difference.
See some more information here https://www.freeview.co.uk/help/reception-picture-and-channels-troubleshooting-guide
One Ui 4.0,Android 12 Official Version.
05-04-2022 04:24 PM in
TV
