The Frame 32” 2020 tilting/twisting Wall Mount Solution
(Topic created on: 13-07-2020 09:24 AM)
Chris_mac
I want to get my 32" Frame on the wall but require it to be angled to view so the flat mount the comes with it isn't suitable.
Has anyone found a way of mounting to an adjustable wall mount?
I have spoken to Samsung live chat and they've just tons me it's not VESA mountable but offered no other solution.
99 REPLIES 99
PompeyCarl
I have just purchased a Future Automation wall box and adjustable bracket for my 43" 'The Frame' TV,  through a UK dealer. This enables the TV to be flush mounted like a picture frame and can then be pulled out and swivelled up to 50 degrees. There are various UK dealers if you search online, but I used Stoneaudio UK as they delivery nationwide and you can purchase online.
There are different size brackets depending on the TV size and different size boxes depending on the TV size and whether you want to store a Samsung One Connect box, Apple TV, Playstation etc.
A good place to start is the Future Automation website https://www.futureautomation.co.uk/TV/Wall-Mount/In-Wall-Articulating
For the 43" Frame I purchased a PS40 bracket + WB21 wall box, as I am not using it for the Connect One box.
For the 32" Future Automation has come up with an all-in-one solution.
 https://www.futureautomation.co.uk/Blog/Post/Samsung-32-Frame-TV-All-In-One-Mounting-Solution
Stoneaudio:- https://www.stoneaudio.co.uk/?manufacturer=future+automation&page=5
HTH
thiagothesaints
ECHOGEAR Corner TV Wall Mount For TVs Up To 65", worked great for me. About 2 inches from the vertical frames can be sawed off the top if you want to really hide the frame, but I didn't mind.
Jimschumie
Hi, did you have any success with the Vogel thin 445?
thanks
Jimschumie
Excuse me, I mean the 545
Jack1812
Hi Jim, I think I just had a question from you. Sadly Vogel couldn't be bothered to reply despite several polite reminders. I've given up and just use the Frame flat on the wall.
Denis Highfield
Hi there did it work
Denis Highfield
Hi there denz this thus bracket work
MarkP63
Hi, I too have purchased these two kits as the solution looks good. Couldn't see any of the wing nuts shown in your pictures above?  Was the included bolts not usable?  Did you need to purchase additional fixings? Thanks
MarkP63
