The Frame 32” 2020 tilting/twisting Wall Mount Solution
(Topic created on: 13-07-2020 09:24 AM)
Chris_mac
I want to get my 32" Frame on the wall but require it to be angled to view so the flat mount the comes with it isn't suitable.
Has anyone found a way of mounting to an adjustable wall mount?
I have spoken to Samsung live chat and they've just tons me it's not VESA mountable but offered no other solution.
98 REPLIES 98
kalli eagle speaker
hi arena75! im currently interested in a 32" the frame. did you buy the one the original user (devi?) suggested, even though the inch is off?
I found this one on amazon, and i'm uncertain if it will work. https://www.amazon.ca/Sanus-VMPL50A-B1-32-Inch-60-Inch-Visionmount/dp/B003WUBL0S/ref=sr_1_12?dchild=...
kalli eagle speaker
this worked for the 32" the frame, but the mount is for a 47" tv? i'm interested in your solution, i just wanted to double check!
kalli eagle speaker
can we see what your tv looks like at an angle?
vk88
I bought a frame TV and returned it because I couldn't use a swivel mount. What iOS Samsung going to do to fix the problem???
b23
Hey there, I was wondering if you were able to confirm if the Vogel's THIN 545 mount worked successfully for mounting the Samsung 32" Frame?  Did you have any issues when trying it? I'm hoping that it worked and will be looking to purchase if so. Thank you!
MarkP58
Looks good although wall plate looks huge at 18ins wide?
MarkP58
Could you (or anyone) please answer 2 questions regarding this bracket (Sanus Vuepoint F180-B2 for Samsung Frame 32);
1) The reach from the wall is shown as 15ins. What are the individual lengths of each arm?
2) I am trying to work out if this will allow mounting across a corner of a wall, arm/wallplate mounted on one wall, arm slightly bent to allow some adjustment to sit TV across both walls
like below photo...
MarkP58
So did the DQ bracket fit ok on the Sanus TV mounting plate? As they are 2 different designs/makes?  Thanks.  The wall plate of the Sanus looks huge from the dog so would rather not use that bit..
MarkP58
The Vogels Thin 545 Frame height appears to be 449mm and the Frame 32 TV is 419.4mm so doesn't the 545 frame protrude the TV by 30mm and show?  I discounted this because of these dimension? Please correct me if I am wrong. tks
