Go to solution Solved
Subtitles not working
(Topic created on: 28-03-2023 10:10 PM)
Shazza3
Hi just recently got a QE43Q60BAUXXU tv. Subtitles are turned on in the settings but aren’t showing on any programmes. I’ve checked for updates but it says it’s up to date. Any ideas please. Thanks
AndrewL
@Shazza3: If you're watching TV via an aerial connection, then you can enable subtitles via the steps below.
Home > Menu > Settings > All Settings > General & Privacy > Accessibility > Subtitle Settings > Subtitle > On.
For connected external devices, or when viewing programmes via a streaming app, please check the settings of the device or application, as the subtitles will need to be set up independently.
8 REPLIES 8
CoolMcCoolson
Voyager
Try enabling them inside of the app settings
Shazza3
Thanks will give that a try
AndrewL
mugox123
I embedded lyrics in *srt format but the TV states that the subtitle fuction is unavailable. The model is UA40J5200AK
neilvanv34
I need to talk to someone.  I don' have the knowledge to follow your instructions.  I tried but it doesn't work
AsadM
The steps may slightly vary depending on the age of your TV. What are you trying to enable subtitles on, @neilvanv34? Do you have anything connected to your TV?
Members_FONMZep
Hello i have a qeustion.  On my samsu.g smart tv Qe85 are the subtiele Grey i cant put it on
PoWingWah
I have got to the subtiltle setting but it showed subtitle setting not available.   What does it mean?
