stream error Smart iptv 2019 samsung QE55Q85RALXXN
(Topic created on: 08-07-2020 11:28 PM)
Anikulapo
Hi team, I uploaded chanels or m3u url on my smart iptv app on my samsung 2019 QE55Q85. I had stream error and then cannot connect message when trying to watch. The m3u url is perfectly working on other devices and smart TV. I tried to fix the issue with different solutions (remove the list and upload one more time/ uninstall + re install iptv app, using another iptv app, turn Ipv6 on my internt box...). All this not working.  Are you facing this issue? Please need your help.
5 REPLIES 5
Anikulapo
Any information please?
henriquerg
I have same problem with Samsung 58ru7100.
Hschulbach
Hi, go to settings, network, expert settings, and disable ipv6
bulentdeg
Hi, I have the same issue and trying to disable the IPV6 but that setting is missing in the menu. Under "General --> Network --> Expert Settings" menu, I have only "Power on with Mobile" option. Is there a way to bring IPV6 setting option there?
Thanks,
Bulent
MMT4
Same thing happens to me, I saw some other post that says to change the option from your router but mine is too old i think.
