sound bar hw-j250, green light stays on
(Topic created on: 25-10-2018 01:54 PM)
bud53
I have a samsung HW-J250 sound bar. i am using the optical connection, i have had this a long time works fine, but now the green light stays on after i turn it off either using auto power or on/off switch. the lights on top are white for optical connect and white for type of sound. any thoughts?
figured it out, had blue tooth on, turned it off, aall set.
1 REPLY 1
ChrisM
SuperStar
Great to hear you got it sorted, @bud53! Thanks for letting us know!
