Smart tv wifi isdues
(Topic created on: 02-01-2023 05:47 PM)
jul74
TV
Anyone had the WiFi suddenly stop working on a Samsung smart tv. It stopped last night- has option of correct network but can't connect. We have spent all day trying different options and it's now back to factory settings. Everything else in the house can connect to the WiFi and the sky box connects to the tv.
5 REPLIES 5
pete007
Big Cheese
TV
Can you log into your router ?? As this will tell you what is connected and what is not.
If you TV is listed you should be able to give it exclusive access. This might help with the connection problems.
jul74
TV
Hello, yes we did that. All the smart speakers and phones were listed, but not the TV. Not sure how to add it (Talktalk router if that's important).
pete007
Big Cheese
TV
You should be able to add the TV if you know it's ip address
jul74
TV
I'll give it a go now.
Fiona26
Samsung Maker ★
TV
I don't have a sumsung TV, my LG did the same thing. Turning it off by the mains for a few minutes, then turning the switch back on. It finally managed to connect back to the Internet. Hope it's just what your TV needs to connect again.
