Go to solution Solved
Smart TV remote voice speaking way too fast! Help!
(Topic created on: 18-03-2018 04:40 PM)
TjonC
My Samsung Smart TV (Model UN49M8000) remote control that speaks is now speaking 100 times its normal speed. She is speaking so fast, you can’t understand anything she says.
I have tried changing batteries and resetting it and nothing works. Getting very frustrated as we just got this TV less than 6 weeks ago.
Any help or suggestions will be greatly appreciated!
Thank you!
JAMES4578
Samsung Members Star ★★
@Klees wrote:
How do I slow down the voice on the remote
Hi @Klees,  You should be able to change  the Settings in  General Menu-Accessibility.    Whilst I tend not to use Voice Guide  on my  MU set there are settings for Speed, Volume and  Pitch.   Speed ranges from  Very Slow-Very Fast, the  "Normal" setting might be a bit quick.
8 REPLIES 8
7alhoul
Navigator
Hi,
Thus on the smart remote control he has no loudspeaker you want to make reference to the vocal guide (the commentator who comments on your manipulations).
Klees
JAMES4578
doc-can
cannot return to tv remote after using other remote for netflix
Chingas55
How can I turn of the lady from speaking to me each time I use my remote
Chingas55
I want to turn off the lady from speaking to me on the tv every time I use the remote
781 house
How can I slow down voice control
AndrewL
@781 house: Have you had a look at the accepted solution by @JAMES4578 to see if this helps? If not, please confirm the model number of your TV, and I will look into this further for you.
