UE55MU6470 as bluetooth display
(Topic created on: 17-03-2018 11:01 PM)
IanC
I'm trying to set up my UE55MU6470 as a remote display to my laptop.
I try to connect from my laptop, whcih displays a code and asks for confirmation of this code on the TV.
In response, the TV simply displays a message asking for confirmation that my laptop should be permitted access, but nothing displaying a code. If I simply allow access and tell my laptop that the pin is correct, my laptop says the connection has failed, but the TV says it's connected.
Any ideas?
1 REPLY 1
7alhoul
Navigator
Hi ,
do you use Windows 10 on your Laptop?
With Windows 10, it has several problems sharing with multiple devices so if you use it, you can disable the firewall or antivirus.
