Smart tv login issues
(Topic created on: 16-07-2022 10:55 PM)
ranger55
Won't allow  me to login tried setting  up new account  same  issue
12 REPLIES 12
AndrewL
@ranger55: Please can you confirm the model number of the TV, located on the sticker on the back of the device, or in Settings > Support > About this TV?
In the meantime, please can you let me know if you're getting any error messages or notifications when you attempt to sign in to your Samsung account?
ranger55
Hi Andrew thanks for your reply
I hope this helps when I log into my old account it says error 189 iv made new account but won't log in I have checked software oupdate its updated turned tv off at wall took plugout same Issues
ranger55
Hope this helps
ranger55
AndrewL
@ranger55: Thank you for that. Please be aware that I have removed the photo in your previous post, as it contained the serial number of the TV. If you're getting error 189 when attempting to sign in the Samsung account on your UE55MU7000, then this indicates that the TV is unable to connect to our servers. This could be a temporary authentication issue, or your internet connection may be too slow. Focussing on the latter, please ensure that your TV is connected to a stable Wi-Fi router by heading to Settings > General > Network > Network Status. I also recommend unplugging your router at the wall for 30 seconds, then plugging it back in and allowing time for the reset process to complete. Let me know how you get on.
ranger55
.I tried this also come back same issue
Abdulaziz2
Hi i have this problem to and my tv is samsung 7 series(55) it doesn’t let me login ut says that there is something wrong but i know that its not wrong
Tvtirana
Same isue.session expired on my samsung 7 series
Hegilsson
I have the same issue with my new 65" The Frame smart tv. no matter what I do, it just won't let me sign in!
Sometimes I get error 129 but most of the time nothing happens.
When I do it though my computer and use the code from the TV, the computer will tell me that I am sign in, but the TV does nothing. All I can do is cancel.
