03-12-2019 06:27 PM in
TVI have a 5 yr old UN50H 6400 TV that developed a dark line and discoloration below the line. I tried the self diagnostics. It failed all the tests.
based on your experience could you tell me if the panel is busted. Is it worth replacing it?
04-12-2019 09:01 AM - last edited 04-12-2019 09:02 AM ) in
TVYes its a problem that needs fixing. Depends on where you live , cost of repair would be around 400. You are better off geting a same size TV now with better picture quality and features now a days.
I have had the same line at the bottom on my tv Samsung 2012 Model Full HD 3D 6 series. ( forgot the model number) . First the right side a 10x10 section started flickering and then it mended it self after a few days. Whats left was this line at the bottom which was visible all the time. Mine was located 1 inch above the edge on the right side and faded away in the middle of the screen.
