Smart Remote voice recognition not working
(Topic created on: 16-09-2018 03:06 PM)
BigDaddyCharles
Hi there!  The voice part of the smart remote stopped working all of a sudden (about 5 fmdays ago). I have tried every suggested ‘fix’ and it still says “You can use voice recognition after setting up a network connection. Would you like to connect to a network now?”. My connection is absolutely sound. Is there anything else I can do (apart from the power of prayer? And tbh that would be a bit frivolous!). I know it’s a 1st world problem... Best, BDC
24 REPLIES 24
CarlH
Hi @BigDaddyCharles. What model number is your TV? Can you also tell me the software version you're currently running?
JAMES4578
Samsung Members Star ★★
Hi @BigDaddyCharles, as @CarlH has indicated check you have the latest firmware  update for your  TV - you can find information on Samsung support by entering your model no https://www.samsung.com/uk/support/ and can download latest firmware via USB and update that way.  if you have the most up to date software or this does not solve the issue have you  reset the bluetooth connection by following these steps ?
1. Switch the TV off.
2.  On the remote, hold down the "back (Return)" button and the "4 Colour" button together for about 15 seconds until the LED stops flashing. This process will reset the remote and unpair it from the TV.
3. Switch the TV on and the bluetooth connection between remote and TV  should re-pair.
Whilst your internet may be fine you could  also reset the connection to see if that makes any difference.
landpal1477
i have the problem as bigdaddycharles,  unable to change channels using voice regogination using temote.
my tv in model No ua436100wxxy  purchased 2 years ago, can any body help or advise, please, Paul
Mudasir
My tv is not taking the voice command .Kindly guide me
JAMES4578
Hi @Mudasir  Have you checked TV has latest firmware  and if so reset the Bluetooth connection on the remote as I have explained two posts above?
cyncerelyurz
I am having the same issue. My voice commands worked fine until recently now anything I say asks if I want to search for it. Very frustrating. I've already reset the TV and remote to no avail. Please advise.20200606_061329.jpg
Cdnviking
I'm having the identical problem. Did they stop supporting this feature? I've reset my tv and remote, as per above, but nothing. All the voice command wants to do now is search.
Jdmgirl127
Same  have you been able  to  fix it
Cdnviking
No. Not as of yet. I have a call in to Samsung technical support. Waiting a reply.
