16-09-2018 03:06 PM
Hi there! The voice part of the smart remote stopped working all of a sudden (about 5 fmdays ago). I have tried every suggested ‘fix’ and it still says “You can use voice recognition after setting up a network connection. Would you like to connect to a network now?”. My connection is absolutely sound. Is there anything else I can do (apart from the power of prayer? And tbh that would be a bit frivolous!). I know it’s a 1st world problem... Best, BDC
09-04-2022 08:23 PM
Thank you for this!! Never managed to get the feature to work but it does now!! Wish i read this 8 months ago
26-11-2022 09:56 AM
I got mine working by repairing the remote using the back and play buttons. None of the other fixes on here worked.
18-01-2023 02:23 PM
Holding the back button and the four colored dot button worked for me!!! Turned the tv off, held them for about 3 seconds and it worked. Thanks!!!
24-01-2023 09:58 PM
Worked perfectly. Just made an account to upvote and thank you
