Smart Remote Compatibility with TV Model RU 7100
(Topic created on: 06-12-2019 10:11 AM)
AyyazKhan
I have Samsung 55" UHD 4K Flat Smart TV Model: RU7100. I want to use Smart Remote Control Model: TM1950A with my TV? Can anyone guide, will this remote work with my TV or not?
Thank you.
Ayyaz
17 REPLIES 17
i0kirill
Original one
kkuba
Thanks for the quick answer :smiling-face:
ppeterts
Almost !
This is for a UN not a UA
Unsure what the difference in model is
UA75RU7100WXXYD
ppeterts
I have a UA75RU7100 with the terrible TM standard remote. I have been able to use the bluetooth remote from our Q9 to connect to this TV. I found this video where you adjust a few settings and it worked a charm. voice doesnt work. I am very very pleased to be rid of the old lightweight piece of clumsy junk .
https://www.youtube.com/watch?v=mVpbVKMo1HU
Swed_Andreas
Use this guide , works great: https://www.youtube.com/watch?v=mVpbVKMo1HU
Works perfect to activate Smart Remote function on my Samsung UE75RU7105KXXC, I paired it with Original Smart remote BN59-01312B ( RMCSPR1BP1 )
Kianm
I had same Problem, the smart control option is disabled by default configuration, you must enable this option before pairing in service menu( press this keys with sequence info+setting+mute+Power while your tv is off)
ztevil
I saw that the smart remote was missing on page 9, so I immediately called my dealer...
Solid advice ! After half an hour I forgot I even had a TV so it worked. A bit expensive but it worked.
Follow-up question; If i go look on page 9 tomorrow should I call my dealer again ?
Kuusysipiste
Can someone help i have samsung UE75RU7025K and im trying to find smart remote for this and i dont know what should i buy so it would work
