Remote control
(Topic created on: 29-03-2025 05:49 PM)
Members_Fra
Hi,
I replaced my TV from the UE40H6400AYXZT model to the QE43Q60DAUXZT model
I would like to know if it is possible to use the remote control of the UE40H6400AYXZT model also on the QE43Q60DAUXZT model
If this is not possible, if I buy a universal remote control, are there problems for a TV to have two remote controls?
Thanks
1 REPLY 1
johnz237
Samsung Members Star ★
Normally, the remotes can be used in multiple models. So, maybe it is worth a try- cant find exact compatibility
If not I would recommend a One-for-All samaung remote.
