Smart hub is being updated. Please try again later. HELP!!
(Topic created on: 27-01-2021 02:26 AM)
dragonsun
Hi! I need help!
I reset my smart hub and now my default apps disappeared (youtube, netflix) and when i try to install them back, the 'download' button is un-clickable and it says below "Smart hub is being updated. Please try again later".
My storage also says 0 KB available and 1 GB used when the only apps available to me right now are, web broswer and e-manual.
I did self diagnosis on smart hub connection test and i got stuck on step 5 where it says "unable to complete samsung apps test" ERR08005
I tried resetting agad the smart hub, factory reset the tv both from menu and service menu but nothing seems to work. I also tried changing dns server to 8.8.8.8 and 8.8.4.4 yet it still don't work.
Model no. - UA43J5500
PLEASE HELP. it's been 2 days 😭
7 REPLIES 7
TessM
Mastermind
Hey @dragonsun ,
I can see that you've got a US model TV.  With Samsung support being localised and this being a European forum (the English language part is supported by the Samsung UK & Ireland team, for example), we're limited in what we can do for you in terms of direct support.
Have you been in touch with Samsung US about this issue, or shared it on the Samsung US Community (https://us.community.samsung.com/t5/TVs/ct-p/get-help-tvs)  to see if others in the US are reporting the same?
CGM356
Seems like my Smart Hub has disappeared. I have internet and wifi throughout the house NO PROBLEM. I can view amazon products through fire stick and same with chromecast but everything SMART HUB has disappeared. I know it is the TV but what else is there to do when you have completed the shut down, the smart hub reset, self diagnosis, TV is updated, Factory reset etc. Now I have this huge SMART TV and am NOT able to use any of its SMART features because they are not showing. I am not able to agree to terms and conditions because the server is under maintenance for days now and can't start the SMART HUB because of the ERROR CODE 202 occurs when performing the Smart Hub Connection Test. It's not the WIFI or Internet Service because all other devices have connected without issues. Also, the devices that connect without issues are NOT being used all at the same time. ANY other suggestions. I would hate to call for SAMSUNG SERVICE and be charged when clearly this one is on THE SAMSUNG PRODUCT
CGM356
Smart Hub connection test STOPS at 3. ISP Blocking test in progress. Error code 202 occurs. END RESULT STILL NO SMART HUB. Thanks Samsung
Vaibhavg
My Smart Tv's Model No -UA32J4300 it is showing error ERRO08007 ie your smart hub is being updated how can i fixed i tried every possible method like factory reset , smart hub reset but nothing works . Please reply if anyone knows how can i fix this problem.
AndrewL
@Vaibhavg: When do you encounter the error message? Can you try powering off the TV and unplugging it at the wall for around 30 seconds, then plug it back in and power the device back on using your remote? Does the issue persist following these steps?
mendi2021
I have problem to setup smart hub, I just made an reset on tv samsung smart and now I am trying to setup smart hub and appeared error 006!
Model tv samsung is: UE55JU7502
Drag0nFly
Have the same or similar issue with my S93C. Running diagnostics it claims "Unable to complete Samsung Apps test" (ERR30001). A Samsung account can also not be created (although it claims one is logged in)
What a wonderful user experience, since everything is linked to your Samsung account (firmware updates(!), app downloads, voice functionality on remote and other basic things)
