Slow internet connection even hard wired
(Topic created on: 21-11-2023 05:50 AM)
Grguy68
My new cu7000 85 tv is hard wired to an optical cable that has 500mbps speed. But it gets only about 20mbps on tv. I tested it with a laptop. The same port and same cable. I got 509mbps on the laptop but only 21mbps on tv. Needless to say, the streaming stucks  often. Really frustrating!! Can anyone provide some real support on the issue? Otherwise, I’ll have to call Amazon to return it.
thanks!
9 REPLIES 9
ChrisM
SuperStar
Hi @Grguy68
Just to confirm, is your TV hard wired directly to your router?
Grguy68
Yes, it is.
ChrisM
SuperStar
Are you using an ethernet cable to make this connection?
Grguy68
Yes, Cat7 cable.
ChrisM
SuperStar
Have a look at the following link from our friends in the US, for some useful connection troubleshooting steps, @Grguy68:
https://www.samsung.com/us/support/troubleshooting/TSG01111046/#tv-will-not-connect-to-my-wired-netw...
Grguy68
Those steps are for tv NOT connect to wired network. My problem is that it is really slow while connected. Nevertheless I still did the reset tv and reset network steps. Result is still the same — with the same port on the router and the same Ethernet cable, my laptop always gets around 500Mbps while the tv only fluctuates around 20Mbps. What other suggestions can we try?
CEO-ROK
Reset your tv to factory
Grguy68
Tried that too. It didn’t help.
Fayaz S
Did you manage to get a fix to this issue? I have the same issue exact same issue.
