Go to solution Solved
Multi output audio
(Topic created on: 21-11-2023 01:57 PM)
Hinod
I have read some posts and answers regarding ‘multi output audio’, but it doesn’t cover my issue.(NB I have not bought a Samsung tv yet because I want to understand how it works before hand).
if you have ‘multi output audio’ active, how do you manage two different sound channels? One being the normal tv sound (with or without sound bar’. The other being Bluetooth earphones.
Hinod
The link is certainly helpfull. Thanks.
1. you could include that that also works for headphones. That is important for people with a hearing impairment. And then the dan adjust the sound level with their headphones.
2. the actual activating of dual output audio is not explained. It has a somewhat obscure location.
3 REPLIES 3
ChrisM
SuperStar
Hi @Hinod
We have a useful guide on how Multi-output Audio works on your TV! Have a look here: https://www.samsung.com/uk/support/tv-audio-video/how-to-use-multioutput-audio-on-your-tv/#:~:text=C...
Hinod
Hinod
And, what is disturbing that in the manual this option is explained as depending on model and region. So the actual test is only in the eating.
fingers crossed that the new tv I expect tomorrow has this feature ….
