Shortcut to Eco mode.
(Topic created on: 04-08-2020 07:03 PM)
ashyt16
Navigator
Is anyone aware of a shortcut to Eco mode without going through the menu settings?
On LG TVs there is a dedicated button for this on the remote and allows to change it from min to max (this is not the auto dim setting) .
It's highly annoying on the Samsung tv to have to navigate through the menu just to do this.
4 REPLIES 4
AndrewL
@ashyt16: Please can you confirm the full model number of your TV, and I will have a look into this for you.
ashyt16
Navigator
Thanks, the TV model is UE49RU7300.
AndrewL
@ashyt16: Thank you for confirming. Sadly there isn't a shortcut on the remote to access the Eco features of the TV. The nearest workaround would be to press the Settings button, located at the bottom left side of the remote, after which you can select 'General > Eco Solution' using the on screen menu to access the Eco features. Apologies for any inconvenience this may cause you.
ashyt16
Navigator
Yes that's the way I access it, but it's too longwinded.
There should be an energy button like on LG and other Tv's, rather have that than a silly Rakuten button.
Bit of silly omission imo in today's day and age.
Thanks anyway for the help.
