Satellite connection with T4300
(Topic created on: 28-12-2022 11:49 AM)
dedorex
TV
I have bought (quite hastly) a T4300. How can I see satellite content on it? I have not found any input for satellite cable. Do I need to bay an additional satellite decoder?
Thank you
3 REPLIES 3
JAMES4578
Samsung Maker ★
TV
Hi @dedorex I take it you are interested in the Freesat service,  whilst you not need a Box as built into the Tv though will not be 4k) customers do need a satellite dish  to receive the Tv service. More information here  https://www.freesat.co.uk/news/tech/what-you-need-for-freesat Tv is the input that needs to be selected.
Aerial needs to be connected to the Ant In  port of the Tv, if you go to Settings-Broadcasting-Auto Tuning Services-Auto Tuning should be able  Tv should be able to scan and find the Freesat services.
Without a dish can access Freeview  (though the signal quality can vary depending on location). https://www.freeview.co.uk/help/equipment
One Ui 5.0,Android 13 .
dedorex
TV
Thanks, but my issue is how to input the satellite signal into the device. I have already the satellite dish.
On the previous device I had a specific plug for satellite cable that on T4300 is not present, as there is only the standard plug for TV antenna.
klfaagffjgsry
Pioneer
TV
Kfsmkddjotwwui
