Samsung tv remote control
(Topic created on: 01-11-2020 06:23 PM)
Bonjeje
This is a terrible design, I couldn't open the remote control to replace the batteries. All efforts to open it proved abortive. Is anyone having the same issue?
2 REPLIES 2
Lisers123
have the same problem ,anyone out there any solution besides throwing it at a wall
AndrewL
@Lisers123: Please can you confirm the model number of your TV, and whether you're referring to the standard remote or the Smart Remote, and I will look into this for you. Alternatively, please check out the handy guide below from our friends at Samsung Australia, to see if this helps.
https://www.samsung.com/au/support/tv-audio-video/how-to-replace-the-remote-control-batteries-of-a-s...
