Samsung tv one connect box
(Topic created on: 28-06-2023 06:51 PM)
lesd19
Just got my new tv today is there anyway to tell if power is going to the one connect box ie light on.
2 REPLIES 2
Neo001
Legend
I have one from 2018 and the only way is to check for the red light underneath the TV. One Connect box gives no indication of "life". Not sure about the newer ones though.
AndrewL
@lesd19: From what I can see, the One Connect Box does not feature a power indicator. As the power supply for the TV itself runs through the One Connect Box, then you can use the standby light on the TV to ensure that power is successfully being passed through.
