05-07-2020 08:51 AM in
TVIn May, I purchased a UE43RU7020K Smart TV from Amazon.co.uk and came a cross an issue when used with a Network Attached Storage device. I use the ZyXEL NSA320S.
The TV successfully recognises it, but for some reason, it doesn't change the files and folders on the NAS to reflect any changes made.
Every time I want to use the NAS source on the TV, it displays the file and folders that were in place when it FIRST connected, meaning I'm unable to use this source, particular as it states there is an error playing the selected file.
Strangely enough, when you put the same video file on a USB memory stick or portable hard drive and connect them through the USB ports, it has no problems playing the file.
I conclude, that because it doesn't refresh the file structure information from the NAS, then it gets confused, hence the errors.
I did ask a question on the subject before, but got no response, so hoping I might this times, as it's very frustrating.
Appreciate any help in resolving this issue, especially as Samsung Support have had two months and not got back to me yet.
31-10-2020 10:11 PM in
TVI have a similar problem, i moved some folders on my synology nas yet theyre duped on the tv. The folders show up at the new place just fine , but also on the old place where the files are inaccessible.
how can i rebuild the database in the samsung tv? (50q70t)
01-11-2020 08:07 AM in
TVUnfortunately, no one has provided a solution and no acknowledgement from Samsung. Its very frustrating and I have stopped using it.
06-07-2021 10:59 PM in
TVAny updates regarding this issue? It seems like network drive support is super wonky at the moment.
07-07-2021 08:09 AM in
TVNope, nothing. Don't think Samsung are interested. Not even been any kind of firmware update either to suggest that they have fixed it without letting people know. Very disappointed with Samsung support.
09-07-2021 08:16 AM in
TVtry renaming a parent folder to rebuild index
09-07-2021 11:22 AM in
TVAlready tried that, but made no difference 😣
06-03-2022 11:53 AM in
TVHello, Did you resolve the issue. I am currently experiencing the same problems with my shared folder over the network.
06-03-2022 12:44 PM in
TVAfraid, no solution and samsung don't seem interested ☹️
06-03-2022 07:59 PM in
TVI have TV and NAS on LAN both via LAN cable. Got same problem. (1) Renamed the parent folder on NAS drive
(2) unplug power from TV for a minute or two (3) turn TV back on (4) found the newly named folder and it all worked. (5) The empty old, nonexistent folder still displayed on TV, just ignore that. (for now)
