05-01-2020 01:50 PM in
TVHi
I have a Samsung ks7000 and it's now about a 2 years old. I've notice that there is a very subtle change in brightness every 2 seconds it's worse on the left side. Even if I pause the TV it still does it or if I do the picture test it still does it. All my eco settings are off and I've tested other HDMI ports. It is very subtle but I notice it alot in dark scenes almost like a flickering. I'm not sure if I should send it in or is there some sort of fix? It is on firmware version is 1241
05-01-2020 03:28 PM in
TV25-01-2020 09:54 AM in
TVHi Andrew, thanks for the reply sorry getting back to you so late I thought I would get notified. I do have all those settings off, it seems to related to the hardware (i think) as it doesn't matter which HDMI channel I choose with all setting turned off, and also it occurs when I pause the image so nothing is happen with picture. If i do the picture test the brightness is still changing constanly it is very subtle but also noticeable and consitently every 2 seconds. Not sure if I should send it in and if this falls under warranty? Thanks
25-01-2020 04:43 PM in
TVHi @Evonian
The warranty on our TV's is for 12 months unless you took out extended warranty with the retailer when purchased. Have you spoken to one of our Audio-Visual specialists regarding this? They'll be able to run through some further troubleshooting with you and advise accordingly. You can contact them between 8am - 10pm, 7 days a week on
0333 000 0333.
Hope this helps!
24-07-2021 02:33 PM in
TVHey Evonian.
Found your post by googling. I have a LG 49UJ6300-SA with the same issue. Exactly each 2 seconds, the image saturation changes. I've reset my TV to factory defaults and the issue still persists. It seems to be a hardware issue, and no specific to the manufacturer. Did you found a fix for this issue?
