Go to solution Solved
Samsung series 7 smart tv
(Topic created on: 04-04-2019 12:10 PM)
BIBURYBILL
Navigator
Dear members i have bt box now tv box uhd player and sound bar all connected to tv with hdmi I am having a problem with tv switching to a blank screen with just sound turning tv off and on brings picture back on also tv comes on at night or morning on its own any ideas ?regards Roy
Dot_Onion
Turn of anynet+ that's what is causing your issue. Anynet controls power over HDMI so when you power the TV off or on it can power down the box.
3 REPLIES 3
ChrisM
SuperStar
Hi @BIBURYBILL
Are you still having this issue? Could you tell us the full model code and software version of your TV? Go to Home > Settings > Support > About This TV.
BIBURYBILL
Navigator
Hi Chris tv is UE43NU7020 software is
T-KTSUDEUC-1202.5   Regards Roy
Dot_Onion
