Go to solution Solved
Remote control 'next' and 'previous' buttons
(Topic created on: 04-04-2019 02:06 PM)
Anonymous User
Not applicable
Hi!
So I have had my Samsung TV (UE40EH6030) for a number of years now, and I'm pretty happy with it. I use the tv a lot for watching media from an external flash drive connected to the USB port. On the bottom row of the remote (AA59-00603A) are the controls for this use case: a play, pause, rewind and fast forward button. Above the rewind and ffw buttons, are icons that seem to suggest a 'previous' and 'next' function, but I have no idea how to actually activate this feature. It looks like I'd need to press some 'shift'-like button like you do on a comuterkeyboard to access the alternate button meaning? Does anyone have an idea?
Thanks!
Example (not my remote, but it looks pretty much the same):
DannyT
Have you tried pressing and holding the buttons down?
Welcome to the Community!
6 REPLIES 6
Chimvux
Me too I have the same problem...I need help
DannyT
Anonymous User
Not applicable
I have had contact with Samsung support since this post, and indeed, you need to press and hold the button. I think for about three or four seconds. It works for me. Good luck!
Cd15
If I hold those buttons in it fast forwards or rewinds it doesn’t skip
Members_OSi5N5E
I have the same problem, it doesn't skip.
But I'm using a remote different from the one that came with my TV
The one I got with my TV has almost no buttons
So I'm guessing it's just not compatible or something.. 😒
Bernie321
Where is pause button on remote?
