06-07-2023 08:49 AM
Hi,
Just started using Samsung QN900B 8K TV and Denon AVC-X4800. Both are great products but I can't make eARC work. There are continuous audio dropouts both with TV programs and streaming apps when using Dolby Surround or Dolby Atmos. Only two channel PCM audio works with eARC. Samsung support re-installed TV's firmware and replaced main board of One Connect Box but it didn't help. Denon support re-installed latest firmware on AVC-X4800 and replaced HDMI card but it didn't help either. Both Samsung and Denon said that this was all they could do to solve the issue. 5 different HDMI cables were tested, certified and non-certified but it did not help. Also several different combinations of settings have been tested.
When reporting findings back to Samsung, they said that there is a possibility for incompatibility like this between Samsung and third party products. Before returning TV and receiver and trying some other products it would be nice hear from other users of Samsung-Denon product combination if you have experienced similar incompatibility issues and managed to solve them. Also information about known working product combinations are highly appreciated when it comes to eARC between 8K TV and AVR. Thank you in advance for your feedback!
Solved! Go to Solution.
18-10-2024 04:04 PM
Just came across this while hooking up my Denon X3800H to my Samsung QN90D and having the audio cut out and this solved it!!
