Samsung QLED TV 2018 Q6F 65
(Topic created on: 28-09-2018 08:54 PM)
C4rol
What bolts to attach the two brackets to the back of the tv - tried the bolts from three different mounts but none of them fit the bottom holes in length - they are far too short -help please
2 REPLIES 2
ChrisM
SuperStar
Hi @C4rol.
Which make and model of wall bracket are you using to mount the TV?
C4rol
Bracket that’s already up -looks as though it’s going to fit just the bottom bolts aren’t long enough
