samsung qled q7f65 and headphones
(Topic created on: 13-05-2019 09:43 PM)
shayyqz
Hi all :smiling-face:
I have samsung tv model Q7F65  (qled tv )
and i want to watch movies with headphones
Usually over the years in previous TVs of Samsung I was connecting headphones to the Headphone jack in Samsung TV
And now  in this model of tv does not have Headphone jack  connection
i was allready try to connect  - optical to analog adapters but
But the sound is weak and not quality
The volume can not be adjusted
And it requires every time to re-connect the equipment and spend precious time.
THE TV ALSO  SUPPORT BLUETOOTH CONNECTION
But I searched and searched and did not find any  Samsung Bluetooth headphones  designed for movies
It's important to me that there be quality sound
also volume adjustment
and good battery
If anyone has suggestions or another solution How can I hear with headphones on this TV I would be appreciate for your help
thanks
2 REPLIES 2
shayyqz
anyone ?
paul1277
Black Belt
and good battery
thanks
Causing a problem this removal of the headphone socket. Don't why they did that.
If the tv has Bluetooth then any Bluetooth headphones should work, you don't need a Samsung set.
Paul
