03-08-2020 03:35 PM in
My Samsung Qled Q70R TV has lost live TV and its says no signal . All other TVs work in the house so aerial must be ok. anybody have any ideas.
03-08-2020 04:50 PM in
Hi @Gus11 i take it you are using Freeview. Can you just check the Tv is set to the correct source and even if so switch to another source and then back again. Go to Support-Self Diagnosis- Picture Test. If no problems messages displays check your external connections and check for updates. However of this does not sort it you should retune the channels. https://www.freeview.co.uk/help/retune Try Auto change first but sometimes manual retune can be necessary. https://www.freeview.co.uk/help/retune
If still issues you could try a factory reset and or unplugging from the mains for 5-10 minutes and disconnecting cables before trying again.
One Ui 5.1,Android 13 .
