13-12-2021 12:55 AM in
TVHey guys. I'm having some bad issues with the connect box of my Samsung 75Q95T.
Anytime the TV hard reset (so when the QLED logo comes up), I'm having this error message popping up - it seems to indicate the issue is related to the connect box.
I found a way to bypass it by clicking on the Rakuten button on the remote (no other button seems to be working) and it seems to work fine. However I notice that sometime a lot of elements (such as brightness slider, local dimming setting) doesn't work or has no effect when being changed.
Does this means that the one connect box is faulty and needs replacing? Or maybe it's something like the fibre cable connecting the box to the screen?
I'm on the latest firmware (2101.2) and already tried to reset many times.
Anyone already experienced this, or have any clue what is going on?
13-12-2021 07:41 AM - last edited 13-12-2021 07:42 AM ) in
TV07-01-2022 02:51 PM in
TVI am having the exact same problem! When pressing the "Rakuten TV" button the TV turns on as normal... So it can't be the cable or the tv, must be something with the connection box. Any ideas?
