Samsung Q95t earc sound dropouts / lockups
(Topic created on: 31-08-2020 07:39 AM)
sgoodwin
TV
Hi,
I have a Samsung Q95t connected to a Sony STR-1080DN.  When using eARC (TV in passthrough mode) with dolby atmos the sound drops out for a second or two at random intervals, sometimes it recovers, other times, the only way to get it working again is to unplug the tv from the wall and restart it.
I don't have any problems with Dolby atmos audio from the Bluray player to the Sony STR-1080DN just when using eARC through the TV, and the TV appears to the problem as it's the only device that requires the restart.  All Dolby Atmos Audio stops including internal applications like Netflix, Amazon Prime until the power off / restart when it locks up.
Happens at least every hour.  Changed HDMI cables, using 8k HDMI 2.1 with ethernet cables for eARC.
11 REPLIES 11
Neoshan
TV
Hey,
i have a similiar issue with the same tv and eARC. Sometimes, not always, my Denon X2600h reciever just stays mute when i try to use eARC. The AVR recognizes the TV, since it tries to go in fallback mode (PCM Stereo), but even this doesnt work. Normal ARC works flawlessly, by the way.
It appears that the one connect box of the 2020 models has a major problem with eARC. There are many threads about compatibility problems with Sonos ARC, but i assure you that it's not exclusive.
So when will this be fixed? I bought this TV to use the upcoming PS5 with eARC, since my AVR does not support several new gaming related features. Without this function working properly, the device is worthless.
pastormtitus
TV
I'm having the exact same issue with a 55' Q80T.
XBOX Series X connected to HDMI4, soundbar connected to the eARC input (HDMI3). In this setup, I get consistent 2ish second audio drops about every 25 minutes.
I've found more people that have this issue and the one common factor is we all have the Saumsung QLED tvs from 2020. Hopefully Samsung will send out a firmware update to fix this sooner rather than later!
I have a feeling that MORE people are going to have this issue once they start receiving their new consoles.
Charlsburg
Pioneer
TV
Its the same issue as mentioned in this thread:
https://eu.community.samsung.com/t5/tv/potential-major-issue-with-2020-samsung-tv-s-with-one-connect...
Join the band-wagon and curry up some more attention so Samsung puts more than one programmer onto the issue.
Whats happened is they released an update to "fix" it, and naturally its broken it even further.
It effects all 2020 series QLEDs, and thus far Samsung are silent on the matter.
Its not your audio system or cables, its the TV and its software related.
Zinax
TV
Same problem here. Apple TV 4 k connected to HDMI 2, watching Mariah Carey’s Christmas Show on Apple+ and sound dropsout every 15 minutes. EARC connection to JBL 9.1. When Apple TV 4K is connected directly to the bar, pure clear during the whole show.
mancmackem
TV
Same issue here but on optical input using a competitor's sound bar and sub. Happens for 1-2 seconds every few hours. Happened 3 times today. On the latest firmware version (1430 I think).
Andy114
TV
I had exactly the same problem when playing 4 k content via dvd player into hdmi4 on Q80T.   I solved it by turning off Signal Input plus in External device settings.   This is supposed to be on according to Samsung to get better UHD results.  To be honest I can't see any difference and now no sound drops!!
Zinax
TV
Nice, I’ll give it a try!
mancmackem
TV
Cheers Andy, don't think this will work for me though as I'm using optical input. It's just happened again.
alloam
TV
Brand new Q90T on latest firmware and having the same problem while running audio back to my Denon AVR-4400 over eARC. This is so frustrating.
