Samsung N4300 24" smart tv pathetic sound
(Topic created on: 27-06-2023 09:42 PM)
foxinthehouse
Hi Everyone,
I have replaced my old Samsung caravan tv with a Samsung N4300 smart tv. To say I am disappointed with the sound would be an understatement. It is truly pathetic. I have tried using all the sound controls including the equaliser, but the is no marked improvement.
Now I find there is no Bluetooth on this model to connect a speaker.
Can anyone suggest a cheap solution to improving the sound. Bear in mind it is a caravan tv and there is no room for big sound bars. (Or budget!) And it is only occasionally used.
This tv does not have a 3.5mm jack either. Just RCA and Optical as far as I can see.
Thanks for reading.
1 REPLY 1
event2020
I puchased this same TV yesterday and I have now arranged for it to go back for a full refund.
It is a terrible TV, the sound is just dire, not what I expect from Samsung at all.
It's a cheaply built and nasty product, well below the standard that Suamsung is known for.
If, as a company, it is going down the route of Cheap & Nasty then I will look at different brands.
