Go to solution Solved
samsung 8 series web browser
(Topic created on: 13-07-2020 08:04 PM)
I have this problem too
Gregoris
Pioneer
Hey all,
So I have had the samsung 8 series for some time now and I am finding that I dont like the wb browser.  Is there any way I can install chrome? I have to keep using airplay from my mac, but I would prefer to use the TV only if possible, but th browser is not great.
TIA
JAMES4578
Samsung Members Star ★★
@Gregoris wrote:
Hey all,
TIA
Hi @Gregoris  Unfortunately it is not possible to install another Web Browser directly on the TV, any Smart Tv Browser is more limited than a PC/Mac.  other than using Airplay,  casting or screen mirroring  alternative is to use a Media Streamer. However browsers on some of these will not be ideal either.
Some information here:  https://www.lifewire.com/Samsung Tv Browser and Alternatives
2 REPLIES 2
JAMES4578
@Gregoris wrote:
Hey all,
TIA
Gregoris
Pioneer
Hey,
Thank you for your reply.
I dont often need it and airplay is a good option as I can play home made videos dirctly on the TV and it skips a bit using the 5GHz frequency on my router.
The problem is that I watch the F1 and who knows when they will make a smart TV app, so I use the web browser and some of the video content refuses to go full screen mode and I then have to have my laptop plugged in non stop and control it from there, which is a pain. But using chrome from my laptop means it always works and goes into full screen mode.
Shame it cant be installed on the TV, but thanks for your help :smiling-face:
