Go to solution Solved
S93D 77 - QD-OLED or not
(Topic created on: 14-11-2024 10:05 AM)
ViewFromHere
Aiming to pick up the S93D 77
But, while researching (as I'm certain many of us do) I've come across conflicting reports of whether or not the model is QD-OLED or WOLED
If it's WOLED then it's a deal breaker for me I'm afraid.
Hoped/wondered if someone (perhaps Samsung themselves could confirm/clarify)
Specific model number I've found is - QE77S93DAEXXU
Additional information I've found, suggests a panel lottery...
IF I can't get a definitive answer on this, I'm definitely going for the competitor as I don't think I'd be able to return the product once purchased, based on "It hasn't got the screen technology I wanted"
Hope this make sense
Appreciate any feedback
lminvti
Samsung Members Star ★
Hi there 👋 and welcome.
So anything that has AT in the Spec sheet is QD-OLED, and Anything that has AE is WOLED
For example:
QE77S93DAEXXU is WOLED
QE77S95DATXXU Is QD-OLED
If you want 77 QD OLED it has to be S95D
4 REPLIES 4
lminvti
For example:
ViewFromHere
Appreciate that - seems to tie in with some bits I have also read
Decision made then, it's the LG C4 instead - I'm not in the market for stretching to the 95D
Thanks again for taking the time to reply
lminvti
Not a problem glad I was able to help, and all the best with your new TV 👌
SapSur
@lminvti - Requesting your Expertise advise here.
I am looking to buy QE93S93DAEXXU which i believe as you said is WOLED. But I am not able to see much review on S93D. Mostly the internet has review on S90D or S95D. S90D or S93D doesnt have much difference but I got a deal for S93D . So wanted to know whether I can go with S93D - 83 inches. Please give me your view
