25-08-2018 02:44 PM in
TVHello guys! I own a Samsung Smart TV UE4EMU6172U, and after using for some time, I made the decision to factory reset it. The problem is that I forgot the PIN and I can't follow the guides on internet as I have a slightly different remote (image attached with my remote). Please help a man in need. Thanks in advance!
28-08-2018 04:53 PM in
TVHi @Dunkelheit, did you set your own pin originally? if not the default is 0000, but if you changed it then another matter. I also have that smart remote but also a standard one , think easier to reset with the standard one . You could try with a Samsung remote app on mobile though and use standard instruction of ,Mute>8>2>4>Power Reset Pin some info for Smart Remote here though http://hardmasterreset.com/reset-pin-code-samsung-smart-tv/ To change pin go General settings-System Manager on more modern models.
One Ui 4.0,Android 12 Official Version.
01-02-2020 11:08 AM - last edited 01-02-2020 11:14 AM ) in
TVHello everyone, for those who like me a smart remote (digital digit ..) and who lost the pin code here are the 2 solutions for the reset:
1- put the television in standby:
2a- remote control without the microphone button: ps: (mutates this by clicking on the volume button)
press mute, then volume +, then Return, then volume - , then Return, then vol+ , then Return and turn on your TV (Power).
2b- remote control WITH the microphone button:
pushed the vol button up (vol + ), then return, then vol - , then return , then vol + , then Return and Power.
I hope I can help
02-05-2020 01:13 PM in
TVI had the same issue but found a simple fix.
I held both the 'back' and 'play/pause' buttons on the smart remote for 3 seconds to re-pair the bluetooth.
It's been fine ever since.
10-06-2020 07:33 PM in
TVI have tried to reset the pin following the instructions on a smart remote as well as on the app, I have tried different speed but it never works. I am rather sure is not about how fast do I do it, I have been very quick many times. Any idea how to fix this?
06-07-2020 03:06 PM in
TVIt appear that it's impossible to reset PIN on those TV
The only solution to sell the TV and buy non samsung product where you can actually do this simple action (this is the way I decided to go)
12-01-2021 04:49 PM - last edited 12-01-2021 04:51 PM ) in
TV15-02-2022 08:08 PM in
TVI don't know who you are, but right now I love you!
The 2a solution worked for me despite having a remote WITH microphone button.
Now I'm FINALLY able to block those rubbish apps and channels I've never used, this 55" Q70 TV is strictly for PC monitor.
THANK YOU!
