Red colours fading on right side of TV screen. QE65Q85R
(Topic created on: 23-10-2020 07:54 PM)
Shaun7
Help
My TV has just started to look washed out on one side and is gradually creeping across the screen. Reds look pink or purple and blues look green. Skin tones are almost grey. Seems to be missing the ability to process reds.
Any ideas? It's only 18 months old but I don't have a warranty as it was a resale.
7 REPLIES 7
TessM
Mastermind
Hey @Shaun7 ,
is this happening with all the channels and sources? Are you able to send me a picture of this here?
Shaun7
Sorry can't figure out how to put it the right way up. It's a great example with a half faded red coat. All channels and sources affected.
TessM
Mastermind
No worries @Shaun7 .
Can you check the software version and let me know if this is running on the latest version (version 1371.0)? You can check this from the TV Settings> Support> Contact Samsung/About this TV.
Shaun7
I have 1361 and no updates available.
Shaun7
Just updated the software by USB, no improvement.
TheRealRonGotti
I have a QNQ7C and my screen is doing the same thing. Out of warranty. Did Samsung give you any help?
Jean-christophe
Same here. samsung qn65q8, Red is falling. For a 3k Tv only after 3 years. No dammage was done to the TV. no warrenty, samsung on the phone can do nothing. So basicly, tv is ready for Landfill after only 3 years !!!! My old Tv was good even after 10 years.  I will never buy anything from samsung for now. Go with Sony i guess.
