Recording issues
(Topic created on: 28-03-2017 08:10 PM)
Steart
I have a UE50KU6000 operating through an aerial with a new external hard drive with correct spec, the hard drive was formatted by the TV when i plugged it in. Sometimes it records perfectly other times start and finish times are wrong, once it recorded for 12 hours, sometimes it doesn't record a series programme at all. Cannot rely on it all for recording. Any suggestions?
10 REPLIES 10
KellyM
Helping Hand
Hi @Steart,
What software version is your TV running on at the moment?
Have you tried a reset at all? Settings > Support > Self Diagnosis > Reset.
Steart
Software is version 1165, up to date I think. I haven't reset yet. Had on-line diagnostics with Samsung, they thought problem was interference on the signal as the 'bit error level' was high (around 1500). This can upset recording. Will be contacting aerial installer as a result.
KellyM
Helping Hand
Sounds promising, @Steart!
We've also double checked the software for you and it looks like  a newer version (1168) was released a couple of days ago. If you'd like to give that a go as well, it can be downloaded from our website here.
Do let us know how you get on with the Aerial Installer. :smileyhappy:
paul1277
Black Belt
This an issue with a few models which I think Samsung is hiding. I bought 65KS9500ue back in January. Working alright at first and with having Sky did not use recording much. Got rid of Sky in August and the found the TV would not record, it would record a program you were watching and time shift but not from the planner. Samsung had me taking screen shots and all sorts and said the would esculate to next level and then heard nothing. It was on these forum I saw that a factory reset and turn off auto tuning had worked for some, so I tried that, and it worked, joy. Week later stopped working. Again contacted Samsung who informed me that they would send an engineer around to look at it.
Samsung sent Martin Daws to come round but cancelled on the morning saying they did not have the part in, very annoying as I had taken the day off work. They then booked again 3 days later and changed the one box, did not work, another wasted day. Following week came again and changed the main PCB board. Brill all was working, so thanked Samsung and started to enjoy. Two weeks later which was Tuesday just gone noticed it had not recorded Monday nights things. Tested it with programs on Tuesday day and again not working!!!! ( 3 days off work so far) Contacted Samsung and again said they would contact me when thay have further information. Contacted Martin Daws and they said they would have to contact Samsung!!! It's a joke that Samsung can not sort this out.
I also Checked my firmware and it is 1201 but noticed 1208.2 on Samsung support. Downloaded it and updated firmware and tried again and guess what, did not work!!!!! What a joke!!!
WARNING I have found to my very exspensive cost that because I bought the TV from DA Tech (I did contact them and they have basically said its Samsungs problem and have now ignored my emails) through Amazon ( who said because it was over 120 days they can not help). I have lost my credit consumer section 75 protection, because Amazon is classed as a third party, and because I did not report it till after 120 days after purchasse I can not claim a charge back. I have made a complaint to the Financial Ombudsman Service, but with no luck. My only alternative I may have if I do not get this TV fixed is the smaill claim courts under the Oct 2015 European Consumer Regs. Not what I want to do really! Not a Happy Customer!!!!
paul1111
Hotshot
65KS9500 Problem since August 2017 still not fixed!!!!!!!!!!!
I also updated firmware to 1208.2, still will not record from the planner when on of in standby. Now had a new one box, new main board, tried 2 USB drives all over 1 ter and a powered drive, all so turning off auto tuning, factory reset and still it  will not record. The drives have been formatted by the TV and have loads of space. Will time shift and record what I am watching so they do work. I think it must be some thing with the power supply and I now thing it's time for a repacement TV, pleaseeeeeee.
Oh got told off for posting to much. Thing is, if the TV worked or was fixed I would not be here, so come on Samsung sort this out and make some of your customers happy again with their Samsung TV's!!!! and no I will keep posting because you have had plenty of time to sort this out.
paul1277
Black Belt
lat002 wrote:
Hi Paul1277,
I've just re-read your post about the USB ports and hard drives. Samsung in the user manual for your TV state that a hard drive must be connected to the USB (HDD) port and they recommend use of a hard drive with it's own poer adapter (which I know you said you have). I have read of other people having issues with their hard drive when connected to other USB ports so surely it's worth a try?
I have also read that although your TV has 2 tuners, 1 is for Freesat and 1 is for Freeview. If true this is like my TV, so depending upon what TV service you are using (viz: Freesat or Freeview) you could well be having the same problems that I wrote about in my last post. If you are using Freeview you will likely be limited by the Freeview transmission by Multiplex. This is nothing to do with Samsung. If the hard disk that is connected to the TV is recording (say) BBC1 (which is transmitted from Multiplex BBCA), I can only tune the TV into another station using the BBC A multiplex (which are BBC 2 or BBC 4).
For information the list of Freeview chanels and the associated Multiplex can be found on lots of websites. This link is one such: http://www.digitaluk.co.uk/channels/channel_listings
Hope this helps. Good luck!
OK there are 3 USB ports 1 on the TV side, and 2 on the one connect. On the one connect there is a 1 amp and a 0.5 amp USB 2. The 1 amp USB has plenty of power to power a USB drive. I know this because the recording has worked in the past with a Seagate USB plugged into 1 amp port and it worked for a week after I had done a factory reset and disabled auto tuning. I had a new one connect with no luck, and they then changed the main board which worked and recorded every thing as advertised. Then 2 weeks later my last recording was on the 17/11/17 and since then it will not record either when the TV is on or in standby. Thats 3 days of work waiting for the engineers.I have also tried a mains powered USB and again no luck. Thing is it will do timeshift and will record a program I am watching.
As to your comment about tuners this TV has 2 freesat and 2 freeveiw and I do have 2 imputs from my dish for freesat.
I can not understand all the stuff about the multiplex transmissions, because if that was the case it would not have worked in the past. Also why I dissagree with you is because I have a 32inch Samsung Smart TV in another room which has worked from day 1 and still works and records evey thing I ask of it, and the same with a Samsung Freesat recorder I have that also records eveything without any problems.
I don't know if you work for Samsung but this is a list of excusses that are typical of Samsung. They are basically trying to ware us down so we give up, as some I think have. Family have other smart TV's like LG, Sony, Panasonic, and I have been told they all record as advertised and without any of this so called multiplex issues. I also updated the firmware to 1208.2 yesterday which again made no difference apart from slowing the TV down to a crawl, which is another thing to deal with.
I been resonable since August with Samsung and have a new connect and main board PCD fitted and it still will not work. I know with most people it seems to be OK so all I want now is a replacement TV that will work as advertised.
To sum up I have tried all of Samsungs advice (which was very little) 2 USB drives 1 powered USB and a stick drive, had parts of the TV repaced and yet it still does not work. I just can not understand how a company at the leading edge of TV design can not easily sort this out!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Paul
paul1111
Hotshot
Sorry not having it. What about the Samsung TV's that do work OK , are you saying that none will be using a Seagate or Toshiba drive like I have which work in the older set but not the new. Also one drive is USB 3 and one USB 2, also they did work perfectly for a couple of weeks when the main board was changed, so no I find your explanation hard to except, or it might be to take the heat of Samsung so they can blame some one but themselves. Do you know which spec these TV's are in and as I am aware the new spec is to make all USB drives more compatible. Where your argument really falls down is in respect to recording a program I am watching and time shift and program pause which all work fine on the UE65KS9500, it just will not record from the schedule.
@paul1277 wrote:
@lat002 wrote:
Hi Paul1277,
Paul
paul1111
Hotshot
I have had this problem since August with Samsung about the recording issue and no resolution. I bought a Hewlett Packard printer from ebay and it developed a fault on Sunday. I got a replacement yesterday and UPS just picked up the faulty now. That is what I call fantastic customer service, they could not have been more helpful when I spoke to their customer services, and they agreed to an exchange after just 15 mins on the phone. Come on Samsung buck up!
TZ VA
I have a Panasonic PVR with HDMI connection to Samsung TV.  When the PVR commences recording a channel the TV switches to that channel.  How can I stop the channel change? setting?
