Go to solution Solved
QN55Q80TAFXZC and JBL 9.1 atmos issue (eARC)
(Topic created on: 17-09-2020 01:58 PM)
noujach
Hello,
purchased the QN55Q80TAFXZC and JBL 9.1 soundbar. Both devices support atmos. I connected the soundbar via eARC. When navigating in the sound option I am not able to enable the Atmos option. It's grayed out. When I play the Okja movie on Netflix Premium my bar displays Dolby Surround and not Dolby Atmos (since the Atmos logo does not appear on the movie it makes sense).
I factory reset the TV and made sure that the firmware was up to date. I disconnected all devices and remove power on both devices and still not luck.
Is this a known issue ?
Thanks !
IMG_20200916_164641_01.jpgIMG_20200916_164615_01 (1).jpgIMG_20200916_164622_01.jpgIMG_20200917_082122.jpg
theredd
It updated today, I think the firmware is now
20371180 checked it in Google home
15 REPLIES 15
theredd
Hey 👋
I have the same problem with my Q90t and the jbl 9.1 bar. Never got the atmos logo on the jbl bar and never seen it on the native app on the samsung tv.
I used the hdmi earc connection for tv and bar.
The option for atmos is also greyed out so I can not activate it. Read al lot of forums never got it worked for me. Why is it so hard to let it work, you pay a lot of money for these products.
Mnwild
**UPDATE AT BOTTOM**
I have the q90t and jbl 9.1 as well with the same issue. I'm running the nvidia shield through the soundbar to the tv. Earc on auto with passthrough on, but still the dolby atmos capability toggle remains "greyed out". I'm really fearing that samsung won't support this bar for some stupid reason. I am dying for an answer and haven't had luck with threads.
**UPDATE**
I turned on the tv this morning to a notification that read "dolby atmos device detected". I quickly opened the sound settings to find the once greyed out compatibility box solid and already enabled. I opened the Netflix app on my nvidia shield and played an atmos supported tv show. The soundbar read "dolby atmos dd+".
I thought it might have been an overnight patch, but it looks like my software (1301 version) can still be updated - so I really dont know. Now that it is working I dont plan on updating it because I'd risk losing it. I hope whatever changed for me happens for the rest of you and im sorry I cant bring any solid answers.
noujach
Did you check if the soundbar changed firmware version ?
theredd
Can you test if its working on the samsung apps instead of the Nvidia shield? And are you using hdmi 2.1 cables? Or hdmi 2.0 or lower?
Mnwild
When the change happened the soundbar was connected to my wifi so it could have updated while I slept. I reset my soundbar to see if it would have an effect and atmos was still available. I'm not sure how to check the current firmware it is running, but I keep it linked to wifi (through google home) so it updates.
Mnwild
I switched to the samsung tv app, played the source, and checked the sound setting menu - atmos capability still remained and was checked.
I am using two 2.0 cables.
theredd
noujach
You can retrieve the firmware via the google home app.
Mnwild
Thanks.
System firmware version: 20371180
Cast firmware version: 1.40.156411
