QLED Q85R lines horizontal and vertical lines
(Topic created on: 15-10-2022 08:46 PM)
davfox
Not 3 years old and this expensive TV panel appears to have failed. It's 2 years 9 months old. From what i've read elsewhere this requires new panel, so uneconomic to repair. Some have even posted that the panels are no longer available anyway.
Will Samsung help and replace out of warranty because this is rare and they look after their customers?
Video shows fault... https://www.youtube.com/watch?v=OvtavkGDus0
Dave
3 REPLIES 3
leicesterMan
Troubleshooter
If more lines appear I'm sure you need a new screen
davfox
Thanks, I'm a Leicester man too!
If the two lines I have don't change - they haven't for a few weeks - then what you suggest?
leicesterMan
Troubleshooter
The lines will increase over time , I've seen mostly vertical on most tvs .
If that's the case , you'll need a new screen, and it's probably cheaper to buy a new TV, I've always bought from richer sounds London Rd, Leicester, any TV problems usually have been sorted in a few days , yes you can buy cheaper from Costco but richer sounds is for me
