Go to solution Solved
QE55Q95T One Connect Cable Length
(Topic created on: 18-11-2020 10:05 AM)
Womble2020
I am considering purchasing a QE55Q95T, which will be wall mounted and the One Connect box placed in the corner of the room. I have seen different figures quoted for how long the one connect cable is. Can someone confirm how long the cable is that comes with the tv?
Thanks.
ChrisM
SuperStar
Hi @Womble2020
The One Connect cable that comes with our TV's is 5 metres in length. Hope this helps!
3 REPLIES 3
ChrisM
SuperStar
Hi @Womble2020
Womble2020
Thank you for confirming Chris. I have seen different lengths quoted so wasn't sure.
BradleyP
Are longer cables still available for 2022 TVs?
