Q82T (2020) dims massively after 10 seconds, all eco modes etc switched off
(Topic created on: 10-11-2021 12:48 PM)
Doog
When I switch on my Q82T it is perfectly bright and then dims massively after around 10 seconds, making it almost too dark to watch. I've played around with every setting I can find but it makes no difference and the TV does this every time I turn it on.
All eco modes, adaptive brightness etc are turned off and I am using the latest firmware (2101).
This is infuriating me, the TV is less than a year old and it has already been repaired twice for a glitch in the LED display and then a backlight failure.
Is there anything I can do to fix this? This seems like a legitimate fault with the device and should warrant a return or replacement right?
3 REPLIES 3
xSteveuk
Mastermind
Hi,
This page maybe helpful to you
Why does my Samsung TV screen dim or brighten by itself?
https://www.samsung.com/ph/support/tv-audio-video/why-does-my-samsung-tv-screen-dim-or-brighten-by-i...
Doog
Thanks for your reply but this was the first thing I tried, my ambient light detection is turned off and the problem still happens.
xSteveuk
Mastermind
Hi
If still have warranty On the TV
Try contacting support
https://www.samsung.com/uk/support/contact/
