Pin reset on TV
(Topic created on: 17-11-2022 09:01 PM)
Trevor V
TV
Good evening, I have a Samsung TV UE40F6670SB and forgot the pin, tried various ways found on the web to reset to default but nothing has worked 😞 any help appreciated, Thank you
1 REPLY 1
JAMES4578
Samsung Maker ★
TV
Hi @Trevor V  Have you tried the following, different instructions for Smart Remote and standard ones.
For Smart Remote:
Turn on the TV, then press the Volume button.
Press the + button to increase the volume, then press the Return button.
Press the – button to decrease the volume, then press the Return button.
Press the + button again, then the Return button, and the PIN should be reset to 0000.
With a Standard Remote
Turn on the TV,  press the Mute button.
Press the + button,  followed by  the Return button.
Press the - button,followed by the Return button.
Press the + button again, then press the Return button, and  PIN should be reset to 0000.
How to change the pin is also in this Guide:  https://www.samsung.com/ph/support/how-to-find-your-pin-code/
One Ui 5.0,Android 13 .
