Go to solution Solved
Picture quality KU6670 curved
(Topic created on: 13-04-2017 10:07 PM)
Kirky
Hi,
any my one having picture issues with this TV ?
i have Skye with good HDMI, but the picture quality, is not as good as a 2010 Samsung TV.
Would like to know what the best picture settings are please.
MONTY38RAY
Hi make sure you have turned of eco settings to of and in expert settings turn high dynamic to low. The next step would be to reset all setting and start again.
Plus i have not got a sky q box so i would make sure its set to 1080p in settings
and is connected to hmdi 1 and on tv setting make sure hdmi 1 is set to on for uhd
hope that helps
5 REPLIES 5
MONTY38RAY
Hi what picture issues are you having.If you have sky TV set box to 720p and turn of TV motion to stop judder
Kirky
Hi,
The picture appears to be great for dark scenes, but very bright/pale for light. I am using new sky q box. And have turned of to judder. HD channels seem worse !
MONTY38RAY
hope that helps
Kirky
Perfect.
thanks
valleyboy22
Voyager
I have a 55" curved and getting the same problems. White colours not good and getting slight stutter to especially on my android tv box. Pleayed around with settings but not much joy. 4K when i watch stuff is amazing, but we have not entered the age yet where we get 4K tv channels.
