28-02-2019 01:22 PM in
TVHi, I´ve searched, but couldn´t find any information about this.
I have configured my 2018 OneRemote (of my 65q9fn 2018) to turn the volume up and down on my Yamaha AVR, but it doesn´t turn the AVR on and off.
Is this possible?
When I configure it, it does a test turning it off and I accept that it has been turned off, but afterwards it only seems to control the volume
It would be ideal if when I turn the TV on, the AVR turns on at the same time and also when I turn the TV off.
Thanks!!
01-03-2019 02:09 PM in
TVNobody? 😞
04-03-2019 08:27 PM in
TVI'm having the same issue with a Denon Receiver. The test turns it off, but outside of the test I can only control the volume. The receiver won't turn on or off with the Samsung OneRemote.
26-05-2019 05:01 AM in
TVI have the same issue!
23-07-2019 05:57 PM in
TVSame issue with my Onkyo A-9150 amplifier.
02-08-2019 06:47 AM in
TVSame issue with my Yamaha TSR-7850. Tech support must have an answer for this!!!!
24-10-2019 08:04 AM in
TVYou have to set your AV receiver standy-off while no tv signal meaning if there is no signal from your tv the receiever will turn off.
@MilesHi wrote:Hi, I´ve searched, but couldn´t find any information about this.
Is this possible?
Thanks!!
19-12-2019 10:43 AM in
TVSame issue with Sony AV-system (optical output) and Samsung qe55q60ra (+ Samsung one remote)
Set up goes well and AV-system powers up/down during the set up. Volume and mute functions work well with the Samsung one remote but the amplifier won't power up/down when TV is being switched on/off.
Any help? Are there some advanced options on TV that I can't find?
AV-system doesn't have auto-standby functionality and the dealer convinced me that it should control the AV-system (because it's universal).
20-12-2019 03:13 PM in
TVThey seem to not care... as long as the universal remote will universally control Samsung products properly... just install a high power Samsung surround sound receiver processor that doesn't exist... 85" 8k goes great with a soundbar (raspberry sound)...
20-12-2019 11:25 PM in
TVSame issue here, with my Bose Lifestyle T20. I can control volume inputs but power is off limit to me.
The power down test input worked fine as well. This is highly annoying!
